The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Cool. Maybe I’ll give that a try. Thank you.I like this wireless charger because it has active cooling + magnetic mount.
Can hear the active cooling fan in this clip
back of phone has 4 adhesive metal circles adhered to the case
Having a phone mount that causes you to look down is a terrible idea takes your eyes off of the roadCurrently using this. Would like to have my cupholders back. What are you using? Want something that charges wirelessly.
This........I just use the built-in one. I don't rely on it to actually charge the phone to any appreciable degree, but on longer trips, it keeps it from running down while I play music through wireless carplay, or if I have the jb4 app open.
I upgraded my wireless charger to a Qi2 wireless charger (15w) - with a fan!I like this wireless charger because it has active cooling + magnetic mount.
That bad boy right there, that cooks your phone better than an apple pie.View attachment 91485
Wireless smartphone charging (Qi)
The Stinger can charge your smartphone wirelessly and will even alert you if you exit the vehicle and leave your phone behind
The only issue is.............I don't have a wireless charging phone ha ha
This...Can someone tell me what the benefit of wireless charging is over just plugging it in?
I feel like the only benefit is you grab and go with one hand, instead of grabbing and unplugging with two?
I've had 2 previous phones (both OnePlus) burn up the USB-C port while charging via USB-C. Not in the car, but at home overnight. This made it so that I had to use Bluetooth and WiFi to transfer all important files off of my phone with little battery remaining.Can someone tell me what the benefit of wireless charging is over just plugging it in?
The downsides are higher heat issues, worse conversion rate, and takes longer to charge for the same timeframe.
And if you're using AA Wireless... its even worse![]()
Only when the rear heaters are turned on, check and make sure they're set to cool...That bad boy right there, that cooks your phone better than an apple pie.
No, the Qi charging pad integrated into the tray, warms the phone significantly while very slowly charging. There is inadequate ventilation.Only when the rear heaters are turned on, check and make sure they're set to cool...
