AnalogMan
It's been discussed in a few threads how to best connect a battery trickle charger in the Stinger. Some people have connected a trickle charger using the jump points in the engine compartment (positive in the fuse box, negative a bolt on the right inner fender). Others have connected directly to the battery. I've been wanting to permanently attach a pigtail to my car for to make it easier to connect and disconnect.
I sent a query to Kia and was told 'ask your service department.' Two Kia dealer service departments I asked declined to offer any advice since it wasn't a 'factory part.' The last Kia dealer I was at for service finally was willing to give their opinion on this.
FWIW, the tech (who seemed very knowledgable, a real car guy) suggested connecting a pigtail directly to the battery in the trunk. He said that while connecting to the jump points in the engine compartment was also possible, there is still the inherent resistance of 15 ft. of cable to the battery. The jump points are intended primarily to deliver current to the starter motor and electrical system for a jump start more so than charge the battery directly. He commented on how they've had Stingers with nearly dead batteries and have not been able to push enough current through the engine compartment jump points to effectively charge the battery.
With that guidance, I connected my trickle charger pigtail directly to the battery in the trunk (positive to the terminal, negative to the ground in the trunk at the end of about a foot of cable). Even when disconnecting/connecting the battery in the correct sequence, there was much sparking and dramatic flickering of lights in the process of removing or attaching a cable. The pigtail cable is just long enough to emerge from the trunk mat, making it easy to connect the trickle charger in the trunk.
A pleasant little surprise was even after disconnecting the battery to do this, the radio station presets were not changed and didn't have to be reprogrammed.
So far it hasn't melted down the electrical system or set the garage on fire.
BTW, that battery looks monster heavy. When the time comes to replace it, I don't think I'll be lifting it out of the trunk well myself.
