I just wanted to let everyone know that it is the stock amp that is the issue with the subs under the seat. This weekend I took on the task of upgrading the amplifier that powers those speakers in my 2021 GT1 with the HK system. I can attest that this is a true upgrade to those subs. Is it worth the effort? Well, for most people, not likely. For someone like me that enjoys this kind of stuff, then absolutely. Let’s be clear, no one is going to think that you all of a sudden dropped a 12” 500W sub in your trunk. It does, however, make a clear difference in the low end and with them under the seat you get that extra physical impact. My wife even noted that she can feel it in her chest when the bass starts thumping. I agree, I loved it drving to work and back today. Too much power/volume and you can hear them distort before they really thump, but for something that is approximately a 7” sub, it does really good. So far, I am very happy. I am not even sure I will add a dedicated 12" sub anymore.
My install is not the prettiest, maybe even a little hacky. I was mostly focused on just seeing if it would work. I could absolutely do a better job, but it works and is hidden out of site, so works for me.
Here is the basic setup that I used. First, I uploaded the pinout for the HK system. I assume it is the same for all years, but don’t know for sure. I have heard mention that maybe the wire colors changed. I chose to use both the subwoofer and the rear door speaker (woofers) and combine them together using an AudioControl LC7i 6-Channel Line Output Converter (LOC) (Amazon for $129). This allows you to sum/combine the subwoofer and speaker channels into a single “full range” signal. This ensures that I get full control over the frequency and Low Pass filter on my amplifier.
Second, was tapping the speaker wires for their signal using 14–18 AWG splice connectors (quick wire connects from Walmart).
Third, cutting and splicing in the aftermarket amp to the subwoofers. I used 14 AWG butt splice connectors. One set for the output signals from the stock amp to the LC7i and another set for the aftermarket amp output to the subs. I purchased an MB Quart NA-400.2 400W amplifier (Amazon for $88). Can’t beat that price and it is compact and easy to install (made for UTVs and boats). I originally purchased a Soundstream Stealth Double Shot ST2.500D, but it was taking too long to ship and arrive (Amazon $83), but that amp is about half the size!
I ended up using double-sided tape to mount the LC7i to the air pressure vent in the back corner of the trunk. Not perfect, but high-quality double-sided tape is pretty amazing (right up there with duct tape).
I mounted the MB Quart amp near the rear well. I had to drill two small holes and used some self-tapping screws (Home Depot). I attached it to the interlayer of the body, so no harm done.
Hooked up power, ground, etc., and tuned the LOC and amp. I ended up setting the LP filter to around 100 Hz or so. This was a full Saturday job for all of the little stuff and a trip to Walmart. Didn't help it was about 90 degrees in my garage.
Not the prettiest, but believe it or not, it all fit behind the trunk side panel without any fuss!!!
Hope this helps.
Hope this helps.
