I don't know the hose layout at the back of the engine well enough to identify those others in your pictures; I'd have to trace where they connect to figure them out.
But a classic "vacuum leak" would be something like a hose sources vacuum from the intake manifold, to power a closed system like the brake booster. When you disconnect or crack the line, you suddenly have atmospheric air being pulled into the engine without going through the MAP/TMAP/MAF sensor, meaning it's unmetered and makes the car run lean.
A line that is already open to the atmosphere, either because it's feeding air into the crankcase for the PCV, or to the idle air system, isn't a closed source of vacuum, and is already pulling however much atmospheric air as it's going to pull. So a leak in anything that connects to the intake upstream of throttle/MAP, or disconnecting one of those lines entirely, should not change anything.
You said you "hadn't" installed a catch can when you did your intakes, does that mean you have one now? Can you check whether that PCV line is pinched/collapsed (vertical hose on rear left of engine, coming vertically from valve cover to intake)? What other modifications have you done under the hood?
That all makes sense.
I’ll have to take a picture tomorrow when I get the chance, but the PCV line (what the catch can would connect to) looks fine to me, and I haven’t installed my catch can yet (zero maintenance CC from BMS), so that hose has otherwise been untouched.
The timeline for the troubleshooting so far:
Feb. 12th - BMS intakes (just upper intake tubes), No issues/CEL
Feb. 20th - Stock BOV breather hose delete, capped off the breather hose inlet tube with plugs. No issues/CEL
Feb. 22nd - Bumper removed > vellossa tech LED big mouth snorkels installed, oem accordion plastic turbo inlet tubes removed/BMS silicone turbo inlet tubes installed. No IMMEDIATE issues/CEL
Feb. 24th 2pm - 1st hit for P04DB code at 2,460 miles. No reduction in power, no strange noises, no cause for concern beyond CEL.
Feb. 26th 1pm - 2nd hit. Didn’t note mileage but within 20 miles.
Feb. 28th - 3rd hit. Didn’t note mileage again within 20 miles. Checked and tightened connections. Installed Tial BOV and flange, removed oem BOVs. Drove 150 miles hard afterwards for a car cruise, no codes.
Mar. 1st - Drove 300ish miles to the coast and back. No codes.
Mar. 2nd - 4th hit. ~2900 miles, immediately after leaving apartment on first hard acceleration. Reset codes and drove for about 100 miles, no additional codes.
Mar. 3rd - Next morning, 5th hit, similar fashion, first hard acceleration after starting. ~3000 miles.
Mar. 6th - Morning, 6th hit, same first accel. ~3060 miles.
Mar. 7th - No code today, ~3085 mileage as of writing this. Swapped driver side silicone turbo inlet for oem accordion style part. Reverified connection and traced all vacuum lines, identified one slightly oiled area near PCV line but unconfirmed if this is related. No other changes.
After writing this out, I’ve come to realize it’s happening almost regularly every other day. Let’s see if it keeps that trend up now that I’ve swapped the inlet tube out. Should be able to provide an update shortly.
Currently waiting to be installed: JB4, spark plugs, and zero maintenance catch can. Trying to avoid introducing more variables while troubleshooting.
Also not that it matters, but I’m on the younger side, just turned 22. So thank you all for the valuable information, this is all new to me and I don’t know where I’d be without the endless helpful threads created by you guys! And thanks for helping me troubleshoot this issue especially.
