The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Very few cars would have the ability to direct power left to right, and I definitely wouldn't expect it from a FWD-based system like the Kona. All that display is telling you is the degree to which the clutch pack that sends power to the rear is locking up (with actual applied torque being determined by grip).I was hoping to also see left/right vectoring in real time.
Our cars do not possess any left/right power vectoring.I was hoping to also see left/right vectoring in real time.
Good to know. I’ll need to read up on this system a little more.Our cars do not possess any left/right power vectoring.
Instead, we get the opposite, left/right brake application.
Yup.@D.J. has posted some videos that overlay the pressure in our transfer case clutch packs (which control how locked up the front driveshaft is), but again that isn't enough to give you an actual torque split, and from what I remember the pressure was bouncing all over the place meaning it isn't a fixed split.
Can start here...Good to know. I’ll need to read up on this system a little more.
SH-AWD is a FWD-based system, meaning you have a transaxle permanently driving the front wheels, and a clutch that can send power to the rear.My old MDX reflected an active vectoring… it was fantastic to watch in snow/ice, or when hustling through roundabouts.
The Acura system was a little more advanced than that.SH-AWD is a FWD-based system, meaning you have a transaxle permanently driving the front wheels, and a clutch that can send power to the rear.
So with clutches open, it's 100% FWD (maybe 90% because there's always some fluid drag), and with clutches locked they probably quote a 50:50 split, which just means the front & rear axle speeds match (but slip/grip determine actual split).
I believe later SH-AWD systems added a rear LSD or e-Diff, which limits slippage across the axle but can't dictate a specific split. So a display showing corner torque breakdowns is likely just applying a F:R multiplier based on clutch lockup, and maybe a L:R one based on wheel speed differences.
Sorry if that's a downer but I'd imagine 95% of such displays are just synthetic numbers. You could take @D.J.'s clutch duty cycle numbers and display that as front torque percentage (or divide it by 2 so full lockup is "50:50"), but that's still fake (consider a fully locked clutch pack with fronts on ice, or rears on ice).
It's true, the Type SH is more advanced.The Acura system was a little more advanced than that.
Agreed.It's true, the Type SH is more advanced.
But I much prefer driving my AWD Stinger everyday.
Just personal preference I guess.
That is interesting, I'm assuming they just continued to add features to subsequent generations. I guess you could claim "100% of axle torque to one wheel" by adding a lockup diff (with an asterisk that you only get 100% torque to one wheel if the other has zero grip), but putting that behind a FWD-based system trying to siphon power to the rear axle via clutch packs just seems wrong.The Acura system was a little more advanced than that
