7thSonEngineering
- Oct 26, 2024
I purchased a 3.3tt turbo manifold to research the possibility of "Porting" the inside to allow for more flow and less back pressure. My thoughts are that this would benefit oem turbos and Stuffed turbo users.
My initial findings are that the manifold is...
-Cast stainless steel
- Has very thick walls
From my research cast stainless steel is very easy to weld. I of course tried to weld it and I was successful with my first attempt. My next objective is to flow test the oem manifold and then cut it in a strategic spot so that I am able to take a die grinder to it and widen the choke point and entrance to the waste gate area. After this is complete I will weld the manifold back together and flow test it again.
If anyone has a better idea for opening up this manifold please comment.
Attached are photos of the manifold, quick weld and my ideal cut path.
