AusStinger
So for a while now I've had a clunk in the front sway bar.
The cause is the gaps between the bushes and the lateral locking flanges on the sway bar.
I purchased a lateral lock kit and installed it but it didn't do the trick so I purchased a couple of nitrile rubber washers that are 25mm ID ( OD of the front sway bar ).
I took the cradle and bushings off and undid the links from the end of the sway bar and slid the washers over the ends and up against the flanges.
I lubed everything up and re-installed everything including the lateral locks on the outside ( of each side ).
And hey presto !
No more clunk at all.
Hope this helps someone else.
And hey presto !
