Stingabit
Have any of you pulled the passenger side turbo? I am having a heck of a time trying to get to the 14mm nut behind the turbo, the 4th nut on the manifold. I broke a tap off in the flange chasing the threads after stripping the stud out when removing the cats. Any suggestions would be greatly appreciated. I've seen posts saying the engine definitely doesn't have to be pulled to take the turbos out, I just haven't figured
 out what combination of tools to access that dang nut..  this is a pic of the broken tap. If anyone has a suggestion on how I might be able to get that tap out without pulling the turbo I'm open to those suggestions also. Thank you!
		Code:
