PandaThief
- Aug 1, 2024
Are the hose clamps 1/2" hose clamps or 3/4" hose clamps that fit ? - Thanks guys. Pictures will be posted by me.
All of the stock tubing and clamps were used on my Mach2's.
Tight or loose refers to the preload setting of the valve.
The hex head adjuster on the top of the Mach2's. It allows you to adjust the valves release pressure to fine tune the valve.
If you run it loose it may leak between soft shifts at low boost if you run it tight it will hold closed until the highest pressure under HARD acceleration. I wouldn't recommend that.
I took them out of the box and followed the instructions to match them at a little over halfway loose.
They seem to work great at that setting.
If you look at my pic there is a silver hex adjuster in the top that says Spring +/-.
That's the preload for the valve.
