The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
@sutton43, this is a very common issue with the OEM brake pads on the Stinger. We had this issue with our Stinger, but we couldn't find a pad that fit our needs, so we created our own. The K8SS Elite Sport Ceramic Pads will fix the issue caused by OEM pads as well as outperform them. These pads don't squeal or clunk either, and produce much less brake dust. Let me know if you have any questions.Steering wheel shaking when braking fast
www.k8stingerstore.com
That is one of the many solutions.From what I have read on the internet and from my own 55 years of experience, I dare say that the pads for the European version of the Stinger do not have problems that end in vibration under braking. So the solution would be to order them for the European version. I have 72000 km on mine and no sign of vibration
Is there a summary comparison (bite/noise/dust) between the popular options? Could've sworn I saw one a while back but didn't save itThat is one of the many solutions.
Powerstop Z26 and DFC5000 pads seem to work well also
There are countless threads with countless posts, it is extremely difficult to find what you are looking for - a convenient, and accurate summary of various brake pad performance metrics.Is there a summary comparison (bite/noise/dust) between the popular options? Could've sworn I saw one a while back but didn't save it
I think it was this one I was remembering, but it doesn't compare braking characteristics, just lists the options with part numbers:There are countless threads with countless posts, it is extremely difficult to find what you are looking for - a convenient, and accurate summary of various brake pad performance metrics.
If you find it, save it.
stingerforum.org
Now I am curious about the DFC5000 low metallic vs DFC5000 Ceramic.I think it was this one I was remembering, but it doesn't compare braking characteristics, just lists the options with part numbers:
Stinger Brake Pads Replacement
I put together a doc while researching brakes that might help other using this thread and others: Front uses a 1001 “brake slot size” which is pretty generic and thus many options fit this. Difference between generic and car specific seems to be some anti-squeal weights attached that may or...stingerforum.org
Wish you hadn't told me that...DFC ceramics were on my short list. Although at 24k miles I have tons of life left on my stock pads so debating whether it's worth tossing them. I've noticed the pulsing a few times in the last year and a half or so, but a couple firm applications of the brakes has been all it took to clean them up so far.Now I am curious about the DFC5000 low metallic vs DFC5000 Ceramic.
I presently have the DFC 5000 ceramic on my car braking performance is excellent, but after ~20,000 km, they have begun to exhibit minor vibrations.. (likely pad deposits).
Curious if the low metallic version would be better for pad deposits (harsher on rotors) with increased noise.
The pulsations I have currently are minor, was way worse with OEM pads.Wish you hadn't told me that...DFC ceramics were on my short list. Although at 24k miles I have tons of life left on my stock pads so debating whether it's worth tossing them. I've noticed the pulsing a few times in the last year and a half or so, but a couple firm applications of the brakes has been all it took to clean them up so far.
I concur with this line of though.I haven't been able to sus out what happens if you manually downshift and/or control your speed by braking harder rather than very light braking yet, but initial findings on smaller hills and gradients seem to have some promise.
Can confirm that smart cruise will apply the brakes vs. letting your speed rise on hills. Which is why you can get a little better mileage without CC if you have several (building momentum on the downhill then slowing uphill, vs. braking down and accelerating back up).While in smart cruise control going down a large hill, the vibes came back; not as bad as OEM but enough that my wife noticed. When I next stopped, I noticed an imperial buttload (38.7 metric shit-tonnes) of brake dust around the rims.
I think in smart cruise, the brakes are ligltly applied to maintain speed as opposed to downshifting, and I think this might cause, if not exacerbate, the deposits that cause pulsation.
My thinking is that the braking in smart CC down a hill is light enough to spread deposits on the rotors without enough pressure to scour *all* deposits off the rotor, and as the brake force varies, the thickness of the scoured or deposited deposits vary. Hence the pulsation.Can confirm that smart cruise will apply the brakes vs. letting your speed rise on hills. Which is why you can get a little better mileage without CC if you're driving through a series of them (building up momentum on the downhill then slowing uphill, vs. braking down and accelerating back up).
I'm not sure that it would make pad deposits worse though. It's going to be a light, continuous application, which I guess will put some heat into them but you're not coming to a stop where they'd sit against one spot on the rotor, and you have plenty air flow for cooling. I'd expect that it would either gradually grind your rotors clean, or have no effect if the braking is too light...
I have experienced - at least anecdotally, that when I brake more aggressively for a shorter time, rather than gently for a longer time, my rotors tend to remain pulsation free for longer.My thinking is that the braking in smart CC down a hill is light enough to spread deposits on the rotors without enough pressure to scour *all* deposits off the rotor, and as the brake force varies, the thickness of the scoured or deposited deposits vary. Hence the pulsation.
At least that's my hypothesis; I'd need the time and location to actually test it.
Exactly. I'd like to test this scientifically at some point.I have experienced - at least anecdotally, that when I brake more aggressively for a shorter time, rather than gently for a longer time, my rotors tend to remain pulsation free for longer.
Anecdotally
Yup. Except when in Smart CC, the stingers seem to maintain speed by riding the brakes, not downshifting.My method of braking downhill was taught by my dad and I've always employed it. Push firmly and let off, repeat as necessary. Never hold your speed back by riding the brakes downhill. I'll shift into 5th gear to assist with the braking if necessary.
Notably, you can still downshift a few gears, while using Smart Cruise Control..My method of braking downhill was taught by my dad and I've always employed it. Push firmly and let off, repeat as necessary. Never hold your speed back by riding the brakes downhill. I'll shift into 5th gear to assist with the braking if necessary.
