Volfy
1000 Posts Club!
The symptoms of an unbalanced wheel/tire is usually very predictable, so it's relatively easy to diagnose. Unless the wheel/tire is grossly out of balance, you won't hear/feel it at lower speeds. Then above a certain speed, you start to hear/feel a rhythmic pulsing. The higher the speeds, the higher the frequency and amplitude. If it's on the front, it'll get bad enough that above some speed on the hwy, the steering wheel will start to shake.
Slow down the speed of your car, and the rhythmic pulsing will subside. Speed up, and the vibration will get worse again.
