Torque specs for front calipers?
Haha. Thanks, but I’m hoping for something a bit more specific than that.
In general, any fixed caliper to knuckle or floating caliper bracket to knuckle is 'wicked tight'. Use blue loctite. Precise torque isn't actually all that important. "two ugga duggas" would work, too.
what are the torque specs for bolts attaching the front calipers?
I know this is an older thread but I believe the brake caliper bracket is 72.3 to 86.8 lb-ft. However, the brake caliper pins shouldn't be on that tight. That's where I believe the 33 lb/ft is for the caliper pins.
