Stinger weight reduction thread
Damn! You'll be getting a visit from the men in lab coats soon.
I looked at the G70 Al crash bar, looks identical, was it an easy swap? Where did you source it, and will you do the rear as well?
I'm curious how much you can feel that kind of weight loss, but you'll have to pry my cooled seats from my cold dead hands!
Got it from Ebay. It was a direct swap. The rear one is made from some kind of plastic. So I doubt you can save anything there. Plus most of the weight reduction happened in the back of the car. So I don't wanna do anything there.
i recall removing those dampener weights on the front struts when i 1st got the car.
but i put them back on (i forgot why) was everyone running without those as well? that’s probably 7.5 lbs at least
Did you happen to get the exact weights of the G70 vs Stinger front crash bars?
They are gone on mine. Didn't notice any difference without them. But they are 1-1.5 lbs each. Not 7.5. The rear one is heavy. Probably 4-5lbs
And don't forget about engine cover, that's good for another 5lbs, and better cooling. But you will hear that hpfp more. Also, I believe 2018 is the only year that came with aluminum intercooler merge pipe section. That can be replaced with newer plastic one, for another couple of lbs and better efficiency.
As much as I'm nuts about light weight and chassis tuning, these are still first and foremost everyday drivers. I've already cut way too deep into my NVH tolerance scale with the coilovers, I've about reached my limit. For weekend fun at the track/AutoX, yeah, I don't mind ripping out as much as allowed by the rulebook. But everything gets put back in before Monday morning commute.
Those tuned mass dampers on the struts are there for a reason. After I switched to coilovers, I could feel the engine vibration at idle that wasn't there before. Not too obnoxious and not present all the time at idle, but distinctively felt enough for it to be unrelated to the removal of OEM struts. I'm sure the absence of the OEM strut top bearings, with rubber isolators, also played a role. Regardless, the increase in NVH is most definitely there.
That's one area where I'd happily sacrifice an extra pound to quiet that lifter tick / diesel noise from the HPFP. I wonder if wrapping the thing in fiberglass, rubber, or dynamat would muffle it...those things don't run very hot do they?
Looks like the metal bracket above the battery is only there to hold the spare tire up, so if you're removing the spare, you can remove the bracket too.
Skip to 4:40
Skip to 4:40
Our G70 didn't come with a spare tire but did have a different 2-bolt bracket. I had to buy a 3-bolt bracket from a Kia Stinger to mount a spare in it.
I guess it does more than just hold the donut then. Compartment rigidity maybe?
yes the panel would sag down under load otherwise
It's been a couple years since we did that, but IIRC, it was mostly there to keep the trunk floor package shelf/tray from touching the battery. Don't think either bracket does much to hold the battery down. Maybe as a secondary containment, in case the primary hold down clip came off?
Anyhow, one area for easy weight loss is the exhaust. Those dual mufflers are some 25 lbs each, IIRC. On 4-cyl cars, dual-sided exhaust is just plain stupid. Our G70 6MT came with single-sided sport exhaust that made the same 255HP, so there is absolutely no advantage to having two. It just adds dead weight. That is one area I don't mind doing some custom work to shed some pork. I've already done an axle back for our G70 and it came out pretty good. I just bought a DC Sport 3" front pipe for the 2.0T that I'm going to fit on the 2.5T. It isn't a direct drop-in fit, but pretty darn close. Looks like the only work I need to do to it is to shorten it about 2-3inch. I'd like to insert a resonator inline to tame the planned custom exhaust, so I'd have to cut that pipe anyway.
does anyone have the P/N for the hard foam shelf piece that goes there in the well in place of a space tire on some of the Stinger??
the difference probably is not that big. But sunroof would add around 40lbs. I know the front seats are 20lbs heavier than gt ones. 19 inch wheels will add another 10-15 lbs vs 18 inch on gt model. Electronic steering column and rear lift gate mechanism gotta be heavier than manual one. Just the stuff that comes to my head. But I wouldn't be surprised if gt2 is ~100lbs heavier than gt.
The base gt has 19" wheels or are you referring to the gt-line cars with the 18" wheels.
Gt awd came with 18 inch wheels and square setup. At least mine did.
If anyone can find the torque specs for those 3 bolts for the top T bracket, and the 2 bolts for the bracket at the bottom of the battery that actually holds it down, I'll put a nice star next to your name :).
Did you buy it new? Cuz I haven't seen a base gt that didn't come with staggered 19s on it stock. My car is also awd. Only ones I've seen with 18s were the premium and gt-line cars.
