FarmerMagnum
- Apr 7, 2022
Just thought I'd quickly share my experience with this product. I know there's a lot of Lozic stuff out there but most of it seems to be ECU+TCU+AWD stuff.
At this moment I've only purchased the TCU tune. I also have AEM intakes, and a JB4 running Map 4 on E30. I have a 2022 GT2.
My TCU configuration consisted of the following:
Shift Pressure 2
5% Earlier shifts in full auto
Launch Control Torque Limit Off
More Powerful Sport Shift Pattern
I feel like I picked a "mild" setup here - and it's perfect.
First my interaction with Lozic was super easy, he's super nice and very responsive. My product got here WAY faster than I thought possible from Korea
Installation was super easy. Disconnect a plug, 4 nuts, and install in reverse - 15 minutes tops.
The first drive around the block wasn't what I expected. The shifts were a little "flare" feeling and sluggish, the car felt like it shifted super early. I thought something was wrong. However after about a hundred miles the tune has settled in and it is absolutely perfect. Just be aware if you buy this TCU tune you'll need to let it learn a tiny bit before you know what it's like. You can actually feel the shifts in comfort mode now but it's not intrusive. In sport mode everything feels more firm and definite with respect to the shifts. I really like it. When driving hard I still use the paddles instead of letting the car shift itself. I thought I would go the other way with the 5% thing but self shifting still feels faster.
Launch Control: On the factory TCU I could get into launch control just by mashing the brakes and flooring the gas. That doesn't work anymore. Also, previously it would take a second or two for the launch control alert to come up on the screen. To use launch control with the TCU now I must have traction and stability control off and the instant I mash the brakes and floor the gas the alert comes up. When you get your TCU tune and you do this the first time be prepared. I thought I was - I was wrong. The TCU takes launching this car to a whole other level - hell a different planet. It's unbelievable how much harder this car will launch. If you don't let your foot off the brake within about a second of that launch control alert popping up you'll just spin all 4 tires. I firmly believe it's possible to do a 20psi launch here and probably break your transmission or transfer case. If you get this tune be careful and aware when you launch it.
The JB4 was an awesome mod for my car. I didn't think anything would equal it. This TCU tune is equally as impressive and I'm really happy I purchased it. I'd definitely recommend it to anyone else.
Shift Pressure 2
