G
G-473166
I have the same issue on 2019 stinger GT1. Going to take it in to the dealer.
I had/have the same issue. Took it to the dealership several times. Of course they said they didn't hear it, but I personally think the system needs to be burped. Does the car smell like antifreeze? Mine did, still does but it's less and less noise if it's full. Antifreeze kept getting low all the time. But ever since my 3 Rd time taking it back I haven't heard the noise but still have the smell but not as bad as when the coolest/antifreeze was super low. How many miles do you have?I have the same issue on 2019 stinger GT1. Going to take it in to the dealer.
Im not sure if this link will work, but worth a shot
20240418_203038.mp4
drive.google.com
You need to change permission to those with link.Im not sure if this link will work, but worth a shot
20240418_203038.mp4
drive.google.com
Here is a better video. It is me pulling out of my driveway after starting it up from sitting overnight. I also looked over the street thoroughly where I took that video and there is no coolant on the road either, so it has to be leaking inside the car somewhere. It's very odd that it doesn't smell like coolant at all either.That is the coolant level this morning before starting it up, so it dropped about an inch overnight sitting in the garage. Still no puddle under the car.
Sounds like you have air in the system. Have it bleed properly, and you'll be fine. Is your heater blowing hot, when the car is at idle?Here is a better video. It is me pulling out of my driveway after starting it up from sitting overnight. I also looked over the street thoroughly where I took that video and there is no coolant on the road either, so it has to be leaking inside the car somewhere. It's very odd that it doesn't smell like coolant at all either.
20240419_055113.mp4
drive.google.com
The dealer said they bled it when it was in there yesterday. In january when it was -10 here in minnesota it was blowing -10 degree air at idle, wouldn't heat. As soon as I started driving it would blow heat again. I brought it in, dealer said they couldn't replicate it. Seems like they say that every time I bring the car inSounds like you have air in the system. Have it bleed properly, and you'll be fine. Is your heater blowing hot, when the car is at idle?
Heater blowing cold or just warm during idle is a sure sign of the air in system. Try different dealership or you can do it yourself. Just takes time without KDS tool.The dealer said they bled it when it was in there yesterday. In january when it was -10 here in minnesota it was blowing -10 degree air at idle, wouldn't heat. As soon as I started driving it would blow heat again. I brought it in, dealer said they couldn't replicate it. Seems like they say that every time I bring the car in
Omg. Probably leaking internally??! They can't even bleed it! I could see this kind of bs from some kid working at lube stop. Take your car out of there. It's so sad, kia put so much effort in making cars, but completely forgot about dealership network.I dropped it back off today. The tech who worked on it yesterday said he bled the system again this morning. They said it's probably leaking internally and is most likely the head gasket. Hopefully it's not there for months
I took mine for the recall and it happened again. The sloshing noise. I took it right back that following Monday and told them they need to burp it. They did and it's all good so far.Same exact problem here. This car is a pos. Overheated twice last year with blown off radiator hose. Took it in for turbo inlet recall, and the noise is worse now.
