Assuming this is still up to date, the mildest map that BMS/JB4 offers, designed to be safe for 91 octane, adds 4psi down low and 2.5 up high. And I think that's considered to be good for around 30-40hp.
*** We're going to use this thread as the general Kia Stinger informational thread including posting the install guide, mapping guide, software, firmware updates as we release them, logs, and general discussion. *** Order Here! (http://www.burgertuning.com/kia_stinger_jb4.html) Use subject to...
www.jb4tech.com
Map guide as of v15+ firmware (selected via JB4 Mobile/laptop interface. Map1 is the default map)
Map 0: JB4 disabled
Map 1: 4psi over stock peak tapering to 2.5psi at high RPM. Default performance map suitable for all 91+ octane fuels.
Map 2: 5psi over stock tapering to 4psi at high RPM. Suggested for 93+ octane fuel.
Map 3: 6psi stock tapering to 5psi at high RPM. Suggested for high quality fuel including unleaded race gas, ethanol mixtures up to 30%, or high quality octane booster like Torco or Boostane.
Map 4: Up to 7psi over stock. For use with unleaded race fuel and/or E85 mixtures up to 30%.
Map 5: Up to 7psi over stock but without top end taper. For unleaded race fuel use and bolt on modifications. May not be suitable for E85 mixtures due to high fuel pressure dropping. If using this map on E85 you should be experienced at reading your own logs and evaluating ignition advance and fuel pressure.
Map 6: User adjustable map. Enter value of boost over stock by RPM on user adjustment page.
Map 7: Progressive WMI (water/meth) map. Increases boost as a function of methanol flow & methanol boost additive. Holds boost low until WMI is flowing to avoid tip-in knock, and reduces boost as a function of WMI flow in the event of interruption like running out of fluid, leak, or component failure.
Map 8: Valet map, runs around half as much boost as stock.
