GalacticDrew
- Jul 3, 2023
Hey all, new here, I’ve been having an issue with my car (2021 Stinger GT AWD). For about a year now when I reverse down the driveway or out of a parking spot and rotate the wheels all the way (left or right), then shift to drive and rotate the wheels all the way in the other direction I hear a grinding or even clunking sound just as the wheels begin to spin forward. It started softly and only occasionally but now it is basically every time though much louder when the car is cold. I did get the transmission replaced under warranty due to the drive seal leaking fluid and the behavior was unchanged. I have seen similar posts on here but none really came to a solution. Please help if you can!
Edit: Adding video. Described sound can be heard at around the 11 second mark after shifting into drive and turning the wheel to the right as the car starts to roll forward. However, listening to this I hear a quieter but similar sound at 5 seconds when turning the wheel left and rolling in reverse.
