7Andrei7
A few weeks ago I swapped my open diff for an LSD. It's the one that came standard in the "frigid"zone on all EU GT Lines. Mine, same model, came with the open diff as I live in the "temperate" zone of the EU.
Since then, I can definitely feel an improvement in corner exit and the car clearly rotates way faster, especially at low speeds. I can now easily do a donut, something which was impossible with my 2.0 engine and 255 tires.
However, I also see a way more jumpy TC action. I drive 90%+ in comfort mode and with the open diff I could floor it, no worry, and there was almost no TC stepping in. Even below 4 Celsius like the past 2 weeks.
Now, if I'm making a change of direction or it's a little bumpy while I am flooring it (4k+ rpm and 100+ kph) the TC steps in and cuts the power. With the car in Sport mode I could not get the TC to step in. Only in comfort mode.
There could be another explanation: I just bought a new pair of rear winter tires (same as what I had before but they are a new set). Maybe they are more sensitive or the rubber moves around more because they are new. It would be weird but it's worth noting.
Or is there another explanation for this? Could it be because now it's both wheels that slip at the same time and TC decides to cut power? Anyone understands the mechanical logic?
