I bought a used CPO 18 Stinger GT2 last month with 47K miles from a KIA dealer. I have driven it about 2500 miles so far. I have not noticed any performance issues. The turbos spin right up when I step on the gas giving plenty of boost and there are no unusual sounds. The only mod, which came with the car, is a K&N CAI. The K&N air filters look clean. I had the dealer install new spark plugs because there was no service record of the plugs having ever been changed.
A few weeks ago I noticed a cloud of white vapor in the rear view mirror when I accelerated hard about 10 minutes into a drive. It was below freezing so I assumed it was just condensation burning off.
Yesterday, I noticed white vapor coming out of the exhaust after a 90 minute trip when I got out and watched the tail pipes while idling. The vapor did not have any obvious odor. I also checked the coolant expansion tank for the first time and noticed the level was well below the low line. I added about 13 oz. of coolant to bring it level with the low line. This morning, after the car had sat overnight, I needed to add another 2 oz. of coolant to bring it level with the low line.
I also checked the oil and noticed the level is about 1/4 inch above the F line on the dipstick. I know the KIA dealer had changed the oil right before I bought the car but I do not know whether they added any coolant. If the coolant in the expansion tank was at the low level line when I bought it, it appears the car has lost about 15 oz of coolant over the past 2500 miles of driving. I checked for leaks in the engine bay and did not see anything wet or anything with the greenish/yellow color of the coolant.
This morning I recorded the exhaust at start up after the car had been parked for 12 hours and then when the car was warmed up after some spirited driving for about 15 minutes.
At start up, there is no visible exhaust: h t t p s://drive.google.com/file/d/13RUqISHwJrOTKlFvx8fQE6c5Z8gHnRgb/view?usp=sharing (remove the spaces between h t t p s to open the link)
After the car was warmed up, you can see visible vapor coming from the tail pipes: h t t p s://drive.google.com/file/d/13R_6ko3VSmZCu5lnIbuQZ2945MOywTO2/view?usp=sharing
Does the amount of visible vapor appear normal?
I will be monitoring the coolant level to see if it drops.
