miketoronto
- Dec 4, 2023
This new update requires a SD card with larger than 32GB capacity, so I use a 64GB with exFAT, but my 2018 Stinger cannot read the 64GB SD card. Any solution?
My 2019 updated with out issue on a 32Gb SD CardThis new update requires a SD card with larger than 32GB capacity, so I use a 64GB with exFAT, but my 2018 Stinger cannot read the 64GB SD card. Any solution?
How are you getting over 32GB?This new update requires a SD card with larger than 32GB capacity, so I use a 64GB with exFAT, but my 2018 Stinger cannot read the 64GB SD card. Any solution?
How do you guys update the software? got a 2018 and never updated the software
Yes, and if your drive is overly large (like 128gb) it'll ask you if you're sure you've selected a flash drive and not your hard drive before it proceeds^^It's been a while since I did an update, but doesn't the kia downloader tool format the usb flash drive to whatever format is appropriate....
