Snicklefritz
Sustaining Member +
- Nov 28, 2022
Not so. You push the sensors ON button on the center console and it stays lit. When you shut down that selection remains. When you start up again the ON button will be lit. The sensors are active up to 11.something MPH.4. Sensors will turn off once a certain speed is reached. To activate again, either need to hit the button or engage reverse.
In my opinion, you should never pull close enough to another vehicle to even be in the green band.I guess this behavior is to avoid annoying noise warnings when pulling close to cars in traffic - I just prefer a visible indicator when I'm close to stuff that I know is active all the time and I don't have to remember to press a button.
