3.3TT Log Check
dppenland
Installed ewg wires running different maps can you please check my logs
I would stay away from MAP3, your throwing timing. Even in MAP2 you are seeing it on higher boost. I like mine to be 0 across the board with an occasional .8 what fuel are you using? Have you changed plugs and gapped down yet?
Yeah I changed plugs to Denso and gapped to what bms suggests. I'm using a mix of 5gal sunoco 110plus unlv and 8 gal 91 shell
did you send them to the Map 6 AI bot thing yet?
Anytime I’ve seen this on my car it’s been a fuel issue. The only time I’ve had good results with MAP3 is with an E85 and 93 mix. I usually do around 4.8 gallons of the E85. On Map2 I can run on just 93. Do you have any other mods outside of the JB4?
Edit: I will mention this as well. I can’t get E85 in my area so the only time I run MAP3 is when I go to Dallas or Austin to visit my kids. When I do, I always do an ECU reset after filling up with the mix. Then go to MAP3. I don’t know if it’s really “required” but I’ve had good results doing this.
O
The only other mods I have are injen Cai and a custom exhaust with stock downpipe. I do have the ewg wires hooked up. Before installing these I feel like the car was way faster
Alright guys, found the problem...or at least one of my issues. One of my harness connects for the ewg wires was not all the way seated and had came loose and also the harness from jb4 to map sensor was not all the way seated. Car has tons of power now! Here's a log with the wires connected as they should've been
Nice! Much cleaner.
