***First off I'm not a professional at reading logs*** but these look pretty good to me. i see some timing corrections through your 2-6 cyl but that's most likely be due to the stock un gapped plugs ( if there are any corrections there you want them to be under 3) nothing to worry about with fuel pressure either got lots of room to add power there typically you dont need to worry about fuel pressure until like maps 3 and up boost levels when you start to up the ethanol %. would recommend
fuel wires to just make sure the jb4 is tweaking your afrs where they should be. last but not least send your logs to
terry@burgertuning.com from the app and he will look them over for you for being a jb4 customer, he wont write out a long explanation of your logs as he is a very busy person but if theres anything out of order he'll be sure to point you in the right direction.
