TPMS failure
Driving this afternoon was in a perfectly functioning car: the TPMS screen would display with alacrity, sometimes before rolling even two minutes; once I swear it came on almost immediately after I shifted to "D". And the "Check System!" warning as I reverse has not repeated.
Hey I'm having the same issue currently but I can't seem to find which connector it is that's loose do you have any pictures of it?
If you get this error on your dash it is likely 1 of the transmitters (TPMS in the tire) is dead, any tire shop has a scanner to check them.
I had it happen after I installed new tires and the shop replaced it for free because they suspected they inadvertently broke it when they installed my new tires. If any 1 or more die it shows that error on the dash.
I'll be terribly surprised if he responds.
Dude hasn't been on the forum since..
The accident.
