Welcome to the hive. I don't, could possibly tire related, If you can provide some more details I'm sure someone will have some more suggestions. What tires are fitted and how long have they been on the car
Hi yes have just got new tyres and wheel alignmentHi everyone I’ve just joined
I have a question does anyone have a problem with their Stinger pulling to the left or right and even after a wheel alignment still does it ?
Welcome, Penny. I’m moving this topic out of the community lounge and into the Stinger suspension forum.Hi everyone I’ve just joined
more details. you don't say which direction yours 'pulls', or how much. often it happens that a drift to the right is normal, both because the default alignment doesn't want a car drifting into oncoming traffic, and the camber of the road will pull a car to the right.Po
Start with the fundamentals... check tires for wear patterns. Check tire pressures. And if you had suspension work/mod done, check and make sure they are done correctly.
I doubt your car's alignment is to blame on that one. Sounds like your fun factor alignment might be a little out of whack. Your affinity toward linear acceleration is dialed up wayyyy too much. Not only is that wearing out your rear tires, it could take a toll on your pocketbook as well. Best to balance your diet with more lateral acceleration. Carving canyons and slicing twisties takes finesse, not HP. I think you'll be much happier overall.My rear tires wear out 3 times faster than the fronts. Can't figure that one out...![]()
Yes for years mine pulled to the left (RHD) no amount of wheel alignments worked. Got front camber- caster kit that worked. I'm lowered though.Hi everyone I’ve just joined
*some track day patients have reported excessive brake pad and front tire wear to equal the rears. If you experience these symptoms, call your doctor.I doubt your car's alignment is to blame on that one. Sounds like your fun factor alignment might be a little out of whack. Your affinity toward linear acceleration is dialed up wayyyy too much. Not only is that wearing out your rear tires, it could take a toll on your pocketbook as well. Best to balance your diet with more lateral acceleration. Carving canyons and slicing twisties takes finesse, not HP. I think you'll be much happier overall.
Take two track days and call me in the morning.![]()
Stop driving during a full moon.My rear tires wear out 3 times faster than the fronts. Can't figure that one out...![]()
What kit did you get for the front to adjust camber as I was not able to find one online.Yes for years mine pulled to the left (RHD) no amount of wheel alignments worked. Got front camber- caster kit that worked. I'm lowered though.
