Tinytags77
- Jul 24, 2021
Hey guys, seeking some advice or opinions from Mechanics or anyone that may be able to help, please!
I have a 2022 Kia Stinger GT. I have a unichip and AEM Cold Air Intakes and running Motul sport oil. It has been tuned and has now 25,000KM.
For the last year it had no issues or missed a beat, however the last few months I have been getting a check engine light. I ended up buying a OBD2 scanner reader to see the codes.
I was getting P0300, P0301, P303, P305. These are cylinder misfires. I spoke to my mechanic who believed it may have been a spark plug issue. I tested to see if it was the Unichip causing the issue by unplugging it and having the car run stock and it was still causing the check engine light.
The check engine light will go away when I turn the car off, and turn it back on.
I ended up getting HKS spark plugs for the stinger however the issue is still there.
Interestingly enough the error codes do sometimes change to P0300, P0302, P0304, P0306.
I found a “way” to work around this issue by driving the car in manual mode and above 3,000RPM until the car is warm and when I see the oil temperature has warmed up, after this I have no issue. The issue seems to happen when the car is cold and I’m able to replicate the issue when it is cold by driving normally and driving in low RPM (below 3,000RPM).
Being a new car though, it is annoying I have this issue. What is weird however is the codes apparently don’t get stored on the ECU when the mechanic checked them and believed I cleared the codes which I explained I didn’t. He also had to change the Diff Oil because it was apparently dirty at 20,000km.
Any advice or thoughts?
