Hacksaw907
For those using the jb4 to reduce boost levels of an ECU tune, what bits do you have enabled? And are you using the map6 boost settings, or the FF/Wastegate values? Or a combination of both?
Been trying to reduce my boost by 4-5 psi on the tune I have, but it's causing some weird behaviour at wot, so just curious what others have done that worked for them.
