Welcome. Just letting you know that I’m moving this topic out of the community lounge and into the Stinger suspension forum.2023 stinger all-wheel drive. Replaced all driver suspension, and still has too much caster. Are they known to be out just a little bit?
waaat?? explain that please.Replaced all driver suspension,
The car was involved in an accident. Structure-wise nothing much. It is that Matt finish. I am the body technician working on the car. It broke the outer tie rod and off of the knuckle. Just a quick break fracture. Other than that nothing much. Didn't that even ruin the tire. Every place everything but the cradle and one letter arm I think it's called. Looking up down through and around they didn't look bad. I've got them coming just to make sure. So the whole suspension will be brand new. But I don't see it bringing the tire bottom in. If anything from the accident it should stretch it out. Camber is just about 2°in.waaat?? explain that please.
thanks for the description. stingers do not have adjustable camber in front. it is a beef many of us share. mine wears the outer edges of the front tires first. if I would not corner hard that would not be a problem. 'my' wheels and tires guys say that I should get coilovers if adjusting front camber is desired. but Imafraid of the ride quality suffering. then there's the expense, the rabbit hole of modding I want to stay away from.Are these cars from the factory set and aligned correctly. Anybody having problems with cars at have not been involved in anything.
The front rail is likely tweaked out of true in the accident. Both our G70/Stinger stayed in the tolerance range (IIRC, right on the money stock at -1.0deg, -1.2 on lowering springs). Other alignment sheets I've seen folks post also showed front numbers staying pretty much in range.The car was involved in an accident. Structure-wise nothing much. It is that Matt finish. I am the body technician working on the car. It broke the outer tie rod and off of the knuckle. Just a quick break fracture. Other than that nothing much. Didn't that even ruin the tire. Every place everything but the cradle and one letter arm I think it's called. Looking up down through and around they didn't look bad. I've got them coming just to make sure. So the whole suspension will be brand new. But I don't see it bringing the tire bottom in. If anything from the accident it should stretch it out. Camber is just about 2°in.
Yes I know what you mean when you start modifying watch the wallet just fly away. Lol. But this is a customer's car very very low mileage. Very new. The accident was not bad. Which leaves me to think that from the beginning Kia stingers have never really lined up.thanks for the description. stingers do not have adjustable camber in front. it is a beef many of us share. mine wears the outer edges of the front tires first. if I would not corner hard that would not be a problem. 'my' wheels and tires guys say that I should get coilovers if adjusting front camber is desired. but Imafraid of the ride quality suffering. then there's the expense, the rabbit hole of modding I want to stay away from.
This is so true. Funny you should mention "rabbit hole". Right after we finished the Riaction coilover install, I told my son this:thanks for the description. stingers do not have adjustable camber in front. it is a beef many of us share. mine wears the outer edges of the front tires first. if I would not corner hard that would not be a problem. 'my' wheels and tires guys say that I should get coilovers if adjusting front camber is desired. but Imafraid of the ride quality suffering. then there's the expense, the rabbit hole of modding I want to stay away from.
I dunno. If the bang-up was enough to break several dog bones, sounds like it could be hard enough to tweak the frame rail ever so slightly. Besides, the rail is the main structure of the front crumple zone that is designed specifically to absorb a large impact energy by deformation... not so much to stay rigid or to bounce back to the original shape.Yes I know what you mean when you start modifying watch the wallet just fly away. Lol. But this is a customer's car very very low mileage. Very new. The accident was not bad. Which leaves me to think that from the beginning Kia stingers have never really lined up.
I appreciate your response. But it didn't do anything that you said. The knuckle was the only thing that fracture. In a very very weak area. I'm going to have the rails measured out. But in my 30 years of experience being a full body technician I've never came across something so minor move rails. I have on the other hand came across Kia Hyundai being crap built. Had a Genesis one time minor pump up. Couldn't get the hood headlights and bumper to line up like I like. So I went to the dealer front line were set 5 Genesis. I look and took pictures of each one. Each one of them brand new cars were different than the other one. Mine was 10 times better than the factory. So when I'm looking for is someone who actually does alignments on these cars. The car that has came in for just a basic alignment. Cuz you know Kia recommends alignment every 6,000 mi. So there should be a whole lot of people out there who has done alignments on these and could tell how bad it is from the factory. That's what I'm asking. Thank you so much for your time and your patience. May you have a wonderful rest of the year. and remember if you go outside it is hotter than hell. At least where I'm atThis is so true. Funny you should mention "rabbit hole". Right after we finished the Riaction coilover install, I told my son this:
I myself have been down the rabbit hole many a times... got a couple of T-shirts and a Cheshire Cat bobblehead. If it were up to me, I would've stopped a long while back, probably even stayed mostly stock. But young Alice wanted to explore, so the White Rabbit is obliged to lead.
lol. you have just graduated from entertaining and informative to funny as well. your fav song is probably 'white rabbit' am I right?I myself have been down the rabbit hole many a times... got a couple of T-shirts and a Cheshire Cat bobblehead.
Hehe... I like so many songs. Not sure which is my favorite. But I am very sure the Original Matrix is one of my all-time favorite movies.lol. you have just graduated from entertaining and informative to funny as well. your fav song is probably 'white rabbit' am I right?
you know how deep you went. it goes a lot deeper even beyond chapter 7 or 13 to infinity and beyond. this is just money talk rabbit holes.This is one of the afore-mentioned T-Shirts I got from finding out how deep the rabbit hole goes:
