I need to check these and things around as I have big adjustments in timing. Engine, turbos, coils HKS plugs are all new. Need to see if sensors is tourqued right oc if something else is rattles and give signal.
Anyone know whereto fins them and also if it possible to reach them like with intake off?
Based on the shop manual they look difficult to get at even with the intake removed. They're pretty deep into the engine bay and doesn't look like much working room.
Definitely above my skill level haha.
Thanks. I have timing issues at left bank, mostly cyl 4 & 6.
Engine is complete new, also turbos, coils, HKS plugs so it's not the engine. Timing also goes down not depending of power so it is sound from anything else that knocksensors pic up. Not a fun problem, especially with sensors location that make it difficult.
Is sensors even possible to reach when engine is in? Most common from other cars, what I heard is like a shield is lose or vibrate that then sensors pic up.
I found the manual a few years back. Not sure where. I'll upload it to Google drive.
I'm too new to post links so dm me and I'll send you a link to the Google drive.
It's a bit hard to navigate all the folders. Knock sensor is under Shop Manual -> 06engine control:fuel control -> 04 engine control system 11: knock sensor
