taamaas
- Mar 13, 2023
Hi all,
After fixing the ignition coil issue, I have noticed two other issues with my car that I am hoping to find a solution for.
Firstly, I have experienced vibration when braking at higher speeds. Although I haven't noticed it at lower speeds, after some spirited driving and braking, I can feel the car and steering wheel vibrating when stepping on the brake pad. I am wondering if I should change the rotors, pads, or maybe both? I would appreciate any recommendations or advice.
Secondly, I have noticed that at higher speeds, when I step on the gas, the car accelerates well, but I sense minor "jumps" as the RPM increases, as though the engine couldn't handle the acceleration. I am not flooring it and the slight "jumping" goes away when I let off the gas a bit, and the Stinger continues to pick up speed. I didn't notice this during heavy accelerations at lower speeds (lower gears). I changed the ignition coil when I got the cylinder 6 misfire code, and it seemed to solve the misfire issue. However, I am wondering if I should change the spark plug for that cylinder as well.
Any ideas or recommendations would be greatly appreciated! Thank you.
