Is anyone able to help read my logs to make sure they're safe.
twokick
I've tried for a couple of hours to get my head around this info but I'm struggling as there is alot to take in and im not sure I'm even heading in the right direction.
i posted my log directly on JB4 forums as i dont know how to read it either.
Logs looks good, no issues. It always helps to post your modifications also. This helps us understand things better if it doesn't look good.. Include the gas you're running too. I think you would be good to run Map3 if you wanted.
Here's a helpful link for reading logs. Between the parameter guidelines and seeing examples on JB4tech, it should get you started on what to look for:
Thank you so much everyone!
The information has been super informative. I hope I can learn enough to help myself and others in the future.
