But Those stiff sidewall comes with penalties:
1.
Weight. again rears its ugly head. There is just no way around this. More load handling out of less sidewall height means more materials and reinforcements. Look up any of the more popular performance tires and you'll see this for yourself. All else being equal, lower profile (less sidewall) will invariably carry a lower load rating, meaning their cannot sustain the same load as a higher profile tire of the same series/dia/width. And... when you do find another tire that does have an equivalent load rating as the higher profile tire, it will be heavier.
2.
Reduce tire compliance. A 20" tire on a Stinger will have to be ultra low profile in order to maintain the same rolling diameter as an 18" tire. This means 255/30R20 vs. 255/40R18. When a tire has that little sidewall - and having to be ultra stiff to carry the same load rating - it simply will not flex at all. While this might not be a big deal on a billiard table smooth race track, most of us drive on roads that are far less forgiving. Over rough pavement and over larger undulations, a tire needs a certain amount of compliance in order to stay adhered to the road surface and to maintain grip. Too stiff a sidewall and too little compliance will simply make the tire bound off the pavement and lose contact/grip. The best tire compound in the world ain't gonna do you much good when it is in the air.
Also, some compliance is necessary for optimum accel and braking. Most folks familiar with drag racing know this.
3.
NVH (Noise, Vibration, and Harshness). Short stiff sidewalls will transmit more NVH (Noise, Vibration, and Harshness) up the wheel, thru the suspension and into the cabin. That means more road noise. That also means your suspension will be more stressed and have to work harder to dampen the additional movement that would have been otherwise absorbed by a more compliant tire.
4.
Road hazards. This brings us inexorably back to the topic of this thread. There is no escaping the fact that your 20" rim - with a 255/30R20 tire - is sitting some 2" off the pavement. Now imagine that wheel/tire hitting a pothole. Even at modest speed of say 60mph, that awfully small "crumple zone" will have a tough time absorbing that impact, before the suspension has a chance to react. Little surprise that Stinger/
G70 forums and FB pages are constantly littered with folks posting their dented/crack rims.
