Overall they look good but understand how difficult it is to review a log on a graph when you've mixed three different maps. The graph doesn't show which map is which pull so we have to play detective. If you want detailed feedback on a particular Map, log just that map and post.
Ign 5 is a bit high but I promise you at this Map it's nothing to be too concerned about, well withing expectations. It looks solid.
You didn't post your mods or fuel.... that helps advice also
You didn't post your mods or fuel.... that helps advice also View attachment 77238
I’m running shell 93 along with hks plugs at .23, kn intakes, Borla exhaust. And I ran a few more cause I just couldn’t help myself! Also just to know which plug correlates with ign 5.
Looks pretty good. I don't see any timing pulls under boost over 2.3 or 3.8 which is reasonable.
Larger numbers at gear shifts I don't count as an issue.
One other note, you're using firmware version 22. The latest stable version is 27 and Beta 28 is out. I recommend pulling down 28, lots of upgrades and enhancements.
