View attachment 4728 View attachment 4730 Quick before and after. Well worth the cash. Very easy to install.
They be factory guards for sure. Had mine installed before delivery by the dealer.Are they factory or aftermarket mud guards?
@Rango, did you have any issues installing the plastic expansion rivets? When I did my install, the rivets on the inside of the front mud guards would not fit all of the way in. Seemed like the thickness of the plastic flange on the mud guards kept the rivets from penetrating far enough for the expansion to happen.View attachment 4728 View attachment 4730 Quick before and after. Well worth the cash. Very easy to install.
Factory ... OEM.Are they factory or aftermarket mud guards?
Thank you!I did have problems with the expansion rivets you are refering to. Used the end of my screwdriver to press the rivets in. Had to press real hard with the screwdriver while pressing the mud guards against the car. Was a pain but finally got them locked in proper.
1/2 of labour I'm guessing max 1 hrDo you think the dealership would charge much to get these installed?
