JB4 map0 and map1 logs 80%throttle Can anyone take a look at them?
terry390
80% throttle
91 octane
bms intake
6ix oil catch can
Ark secondary+Mbrp
JB4+bluetooth+fuel wire
Im new to JB4, I want to make sure the stinger is doing fine before I go on map 2 and beyond.
How do I know if my fuel wires are connected correctly and working?
Thanks in advance.
You should set the JB4 to only log when throttle is at 80 or above, eliminates the extra uninteresting stuff in the log.
Also, try to get a full throttle run starting at about 30mph up to 80.
In the parts where you were seeing boost, I see a few timing corrections, but not bad. Try map 2 and post that log.
thx man.
I will do my logs again and try to avoid any unnecessary logs with 30mph to 80 pulls.
thx man.
Go into the JB4 app, click on "Settings", then under Advanced "JB4 Tuning/App Configs" -> "App Settings" -> "Logging Settings" -> "WOT Start Threshold (Pedal)" and select 80%.
Then it will automatically log when you punch it, no need to start logging manually, just connect the app when you start the car.
i actually did this setting and I still manually turning the log on and off. lol
I just added a new log for map1. will do map2 next time. however im still using stock plugs.
Definitely need to get those swapped out.
Stock plugs won’t last long.
I recommend HKS. More pricey, but they last longer.
That one looks pretty good. A couple pulls in #4 at higher boost but not concerning. Do as @rpoffen says and GET THOSE PLUGS CHANGED ASAP!
Thanks man. will put HKS plugs in soon.
Drop an email to k8 stinger store, tell him you are a new “modder”, he might give you a discount.
will do. thank you for the advice. They r currently out of stock
Well that’s not good.
Be careful of eBay or Amazon, I have heard that there are fake ones being sold cheap.
Kdm warehouse also sold out.
What the heck, must be stuck on a boat somewhere.
