Thinking 295 if I can and 19x9.5 +35 for the front with a 275 tire10.5 wide is already two inches further out than stock. Stock offset is 46.5. You didn't provide a tire size. A 275/35 looks like this:
I think you're pushing it. And how will you match up that deep dish wheel with the front wheel? I think it's going to look odd. Minimal scrub is good; this setup has quite a bit of scrub.Rim & Tire Size Calculator. Custom Offsets
Tire Tech Information - The Wheel Fitment, Tyre Stretch, Rolling Radius and Speedometer Error Calculator. Play with specs, try different settings, compare resultswww.wheel-size.com
I would want to do 9 but the next size is 19x 8.5 +30I don't think so. Nobody on the forum has successfully run that wide in front (if I am mistaken, somebody let us know). You have little clearance for steering, by this model.Rim & Tire Size Calculator. Custom Offsets
Definitely will not fit the back, 10 and 1/2 width You going to want to be closer to 40 for backsetI’m looking for wheels and I found a good deal on some esr cs15 which are 19x10.5 +22, would they fit the back or would I have clearance issues?
My offset in front with TSW "Watkins" is 40, rear 39: widths are 8.5 and 9.5 respectively: a lot of us use those widths, I would say a majority of aftermarket wheels are those widths applied to the Stinger (judging by reading all of the posts over the years on this subject).I would want to do 9 but the next size is 19x 8.5 +30
I have the same widths, but offsets of +32 F and +38RMy offset in front with TSW "Watkins" is 40, rear 39: widths are 8.5 and 9.5 respectively: a lot of us use those widths, I would say a majority of aftermarket wheels are those widths applied to the Stinger (judging by reading all of the posts over the years on this subject).
View attachment 75689View attachment 75690View attachment 75691
