Do I need to remove my JB4 installation for scheduled maintenance?
Kelkeen
I'm not concerned about any remaining warranty (bought used, 2018) and my scheduled 30k maintenance is coming up soon. Any reason I need to pull my JB4? I don't really see any reason other than them noting it is modded but I wanted input from here.
Thanks.
Will they refuse to work on your modded car? Not hardly.
Yes. Remove it.
What's included in a 30K maintenance?
Mostly just inspections. They might try to change spark plugs but I did that myself 3k miles ago. There is nothing of note that requires replacement at 30k miles.
I can't link because i'm a new member but I pulled the info from the manual.
Leave it if you don’t care about warranty.
Plugs at 30K? Seems a bit premature.
I'd be doing things like oil change, filters (engine and cabin), brake fluid flush, diffs (if awd), transfer case. Still, 30K seems a bit early.
I'm speculating. But I have already changed them recently for my JB4 so it won't matter if they recommend it or not.
