Ign readings higher than 6.
Knowa
Central Ohio
Everything I read shows timing ranges from 0-6 but I am getting readings in the 10-15 range in my logs using firmware v21/24//5. From what I understand without Future Use A, IGN readings are true values across cylinders ie. 15,15,15,15,15,15 is no deviation in timing.
Do I need to enable a setting in the JB4 to convert my timings to the truncated 0-6 range or is my engine really struggling?
Here is an example of my logs:
Set FUA to 0 to log timing corrections rather than raw timing in 2-6.
Will that option show as zero if I am not currently connected to the JB4? I can't connect to my car right now but it shows on the app that FUA is already set to 0
Here are some Map 2 pulls.
Denso 1 step plugs @ .022
Injen Intakes
Borla
Shitty Kroger 93 gas
Seems to be some correction done but idk if this would fall into the realm of "ok". Only thing that concerns me is that most of the big corrections seem to be coming from 1 cylinder. I imagine my gas is fairly low quality so I will try getting to a Shell station but other than that my only choices are Marathon, 76, and Speedway.
From what I can see at the end looks fine. Hard to view as log appears modified.
