JERisBRISK
- Apr 19, 2022
That was a real beast of an install, but it’s done. Sort of.
Post-op:
Pre-op:
Stuff of note:
These pipes would be fine if aFe hadn’t moved the air sensor from the front to the side of the charge pipe… as it is now, the Short Ram rests (therefore can rub) against the connector housing. I tried loosening (even removing) all the things and wiggling both pipes six ways from Sunday, but the physics of proximity will not be denied.
As I pointed out elsewhere, I broke the vacuum line Tee when trying to disconnect the hose from one side. Very flimsy part. This also meant the nipple was stuck in the hose, rendering it useless. Went out to the parts store and got a new, ugly nylon Tee and ordered replacement brass ones and some silicone vacuum line from Amazon:
I will have a few spares (heh) so let me know if you need one…
For now, it looks like this:
Tips:
Taking the last elbow (that mates to the intercooler) off the hot side is super helpful for removal.
An automatic ratchet made some (nearly) impossible things trivial. Highly recommended.
I was able to do the whole job (above and below) on jack stands. I just lifted one side of the car. it wound up being enough. Even though I bought pinch-weld adapters, turns out that my low-profile jack + the cross beam is just low enough to get under the side skirt, but too tall to also get under the pinch weld adapters, so I just used the pads on the crossbeam. Worked fine.
Post-op:
Pre-op:
Stuff of note:
Tips:
