7Andrei7
Hi all!
Has anyone changed their front control arm bushings? I have 80k miles with my car and I can feel more and more harshness from the road, depending on the road surface. Stuff like vibration or even some slight shimmy. These symptoms are aggravated under heavy braking.
Very important: there are absolutely no problems on very smooth roads. I could go for an hour with no vibration at 85 mph and the suddenly, on a different portion of the highway significant vibrations occur. And if I brake in those areas everything is aggravated.
What I've done so far:
- replaced wheels and tires - no change - (all were perfectly balanced anyway)
- replaced rotors and pads (with OEM stuff) - no change under driving (no braking) conditions. There was a slightly smoother braking for the first 2k miles or so. Afterwards, heavy braking increases the vibrations again. But, only on some roads.
- checked alignment and it's all fine
- there is no clunking or squeaking and the car does not pull.
The steering input si very sharp under normal conditions.
The car feels nice to drive except on rougher surface highways and under heavy braking on some roads.
Visually the bushings look ok but I really don't know what else could I do.
Thanks!
Thanks!
