New install logs
Is this a new install? What plugs do you have in? Timing doesn't look good and 93 should hold Map2 better.
I have hks m45il’s in. They are stock gap. Do you think it could be fuel or should I lower the gap on the plugs? I have map 1 logs from today I can post
post the map1 log but its most likely fuel. I would try a different station and brand and see what happens.
What engine? What gap? The preset from HKS, .028? Did you verify that was correct? With the M45IL's those should be the 3.3 though.
I'm thinking you will want to gap them smaller, closer to .026.
I have a feeling all that was needed was a ecu reset. I was having 5-6 degrees of timing being pulled on map 0. I reset the ecu and put 91 no eth with 2 gals of e85 and these are the logs currently on map 2
