MLRS777
- May 14, 2022
Running 3.3t, with BMS intakes, Denso spark plugs gapped to .22, running 93, map 1/2 only. The car has run fine for last 2 weeks after installing JB4, after a drive today that went fine map 1 and 2 no issues. I started the car tonight idled fine, put the car in sport mode and map 2. After driving for a few minutes driving 40mph or less when I came to a stop the car started to stutter, transmission seemed off and jerky, and the engine would increase rpm and decrease randomly and rapidly. Pulled off road and parked car the CEL appeared on dash. I read the codes and it showed P0237, says relating to my map sensor. I turned the car off checked for any connections loose/ smells and nothing from what I saw it was dark. I tried to start car idled rough then stalled, tried again car immediately stalled. I got out locked car and attempted to start again, car started idle seemed okay drive around 10 mins 0 boost limp mode, CEL on still, and car ran okay until I came to a stop, and the engine was sputtering/stuttering again pulled into driveway and turned car off. CEL is still present as well as the code. Hoping or wondering if loose connection, or something not seated or plugged in properly? I have work on Monday hope you will see this so I can try solutions tomorrow.
I’ll also add transmission seems to be shifting fine, and no prior issues with car only 15,000 miles fresh oil change Live in Houston, hot temps outside. Hoping for the best but honestly kind of nervous.
