Hi guys I just install jb4 have the wires and plugs upgraded cold air intake BMS but still have a lot of lag currently just plugged but fills sameEtc
Welcome to the forum! I haven't installed the JB4 yet, but there are many others here who have.
Have you searched the forum for similar issues? I did a quick one and came this:
What map are you on?
you should be able to run map 3 and add 5lbs of boost with E30. Unless you are running 91 octane with it. the difference should definitely be noticeable. Time to post up some logs so we can see what's happening.
Do you feel like you are experiencing throttle lag, or turbo lag? For throttle lag, a pedal/throttle controller module can make it feel quite a bit different.
What gap in the plugs? Have you updated the firmware through the app and what map are you running? What does the boost gauge show in the app? Make sure all connections are connected correctly and securely. Any codes in the app? I immediately felt a difference and within 15 min I felt a lot of power when I installed mine.
Email in a JB4 log if you want us to review the tuning end. Maybe you disable the JB4 with incorrect settings.
