Tire sizes questions
StingtheJeep
Can I put 245 35r19s infront and 275 35 r19 in the rear on my awd kia stinger gt2?
Hey StingtheJeep :)
You should be good, on my 2.0 I am going for
245/35/20
285/30/20
There is a lot of threads here on the forum about wheels, I’d check out those and see if any suggestions come up.
Best of luck and congrats with the most underestimated and the absolute best car in the world :cool:
All the best,
Sæmi
My issue is front tire is 25.8 circumference and rear is 26.6. Yours matches up in circumference, would I destroy my drive line?
Welcome. You already know that you're risking mismatched OD front to rear. Nobody can foretell if you are going to trash your "driveline". Mismatched OD is a risk. At what point of disparity does it kick in? Why risk it?
you should be running 275/30/19 not 275/35/19 this is closer to stock OD and the closer to the front OD of the size you have.
No so I got these wheels and tires as a good deal on Facebook. I over looked the incorrect sizes. Even with new tires In front I'm at 1000. I took off stock 18 2018 wheel that have winter tired on them. They weighted at 55 pounds, New tires and wheels I'm at 49 pounds now. I'm guessing stock 18s which I can't find anywhere weight roughly 30 pounds
Put your numbers in here:
I'm currently going thru the same process, my sizes so far are:
255 x 35 x 19 = 26.0 diameter
305 x 30 x 19 = 26.2 diameter
That's a diameter-difference of +0.8% which is less than 1.0% a lot of people say is the limit.
I'm not yet sure what to do. Has anyone run a 1.0% difference front/year with AWD?
you forgot to put your reply.
P
Oh lol, well 245 40r19 +30 off set fit perfectly no rubbing and is flush. The rear 275 35r19 +25 pff set has worked as well. The +40 offset wheels were om back order for 4 months. So I out them on. I've hut bug bumps gone jn parking lots at a sharp angle and the tires have yet to hit the outside of the body. It tucks in fine, so I guess it fits fine for me been running it fine. It does stick out a tad but adds an aggressive look
P
I meant @socalvn haha
Ohh I see how it is I'm not cool enough now lol. Jk
I didn't mean it that way lol, I just saw that the dude replied with a quote but no words of his own.
I'll add your info to the tire/wheel fitment sheet though.
P
Just to clarify, what width are your wheels?
I w
As joking lol, 275 35r19 offset +25 at 9.5 and it fits just enough
Oh I know, still want to update the list anyway though. what about the fronts?
