When I get an oil change my mechanic uses 5W-40. Liqui Moly to be specific. Been using it ever since my second oil change and have had absolutely zero issues.i think 5w40 is fine its not that much thicker than the 5w30 and offers better shear strength at high heat levels , i think its also in the oem service manual for severe service oil .
several weights are fine as long as you meet the temperature range of hapiness .
nice share the results if you find someI would have to agree that since I have used Motul 5w-40 for the past two oil changes the level on the dip stick hasn't moved. I check my oil every week or two. So oil consumption is little to none compared to when I was using 5w-30. When using 5w-30 the oil level would slowly creep down the dip stick throughout the oils life cycle. It would be nice if I could find a 5w-40 that meets API SP or ILSAC GF-6A standards. One thing about Motul 5w-40 is that it is high in calcium which has been known to promote LSPI. So I'm still searching for the best oil for my Stinger.
I use liqui-moly 5w-40I would have to agree that since I have used Motul 5w-40 for the past two oil changes the level on the dip stick hasn't moved. I check my oil every week or two. So oil consumption is little to none compared to when I was using 5w-30. When using 5w-30 the oil level would slowly creep down the dip stick throughout the oils life cycle. It would be nice if I could find a 5w-40 that meets API SP or ILSAC GF-6A standards. One thing about Motul 5w-40 is that it is high in calcium which has been known to promote LSPI. So I'm still searching for the best oil for my Stinger.
I use Liqui Moly 5W-40 and meets API SP. Have had no issues what so ever. This is the product name Liqui Moly Leichtlauf High Tech SAE 5W-40.I would have to agree that since I have used Motul 5w-40 for the past two oil changes the level on the dip stick hasn't moved. I check my oil every week or two. So oil consumption is little to none compared to when I was using 5w-30. When using 5w-30 the oil level would slowly creep down the dip stick throughout the oils life cycle. It would be nice if I could find a 5w-40 that meets API SP or ILSAC GF-6A standards. One thing about Motul 5w-40 is that it is high in calcium which has been known to promote LSPI. So I'm still searching for the best oil for my Stinger.
are you sure its a api sp ?I use liqui-moly 5w-40
Prime example why I shouldn’t be multitasking at work lmao. Mixed the N with a P. But anyway probably gonna be a hard find for API SP. But we are going to see if the other user finds one.are you sure its a api sp ?
Specifications and approvals:
ACEA A3 ∙ ACEA B4 ∙ API SN ∙ BMW Longlife-01 ∙
MB-Approval 229.5 ∙ Peugeot Citroen (PSA) B71 2296
∙ Porsche A40 ∙ Renault RN 0700 ∙ Renault RN 0710
∙ VW 502 00 ∙ VW 505 0
i have like 10 oil dealers here at work not one with those specs in 5/40 .. im using the x-cess 5/40 gen 2 from motul im happy so far and i do 3k oil changes so im sure its finePrime example why I shouldn’t be multitasking at work lmao. Mixed the N with a P. But anyway probably gonna be a hard find for API SP. But we are going to see if the other user finds one.
Through oil analysis is how I found that Motul is high in calcium which has been shown to promote LSPI. You can see in the oil analysis Motul is loaded with calcium compared to all the other oils I have tried. This is why I won't continue to use Motul. I might give AMS oil 5W-40 a try or I might just go back to AMS oil 5W-30 signature series. Since AMS oil 5W-30 was my best oil report so far. AMS oil is the column to the right of my unit averages and Motul is the column to the left of my unit averages. I want a 5w-40 oil that meets API SP standards but I doubt there is one out there.i have like 10 oil dealers here at work not one with those specs in 5/40 .. im using the x-cess 5/40 gen 2 from motul im happy so far and i do 3k oil changes so im sure its fine
I use motul 5w-40 and now you have me thinking of switching it up. How late in the game in the cars life do you think the high calcium could actually affect the car?I would have to agree that since I have used Motul 5w-40 for the past two oil changes the level on the dip stick hasn't moved. I check my oil every week or two. So oil consumption is little to none compared to when I was using 5w-30. When using 5w-30 the oil level would slowly creep down the dip stick throughout the oils life cycle. It would be nice if I could find a 5w-40 that meets API SP or ILSAC GF-6A standards. One thing about Motul 5w-40 is that it is high in calcium which has been known to promote LSPI. So I'm still searching for the best oil for my Stinger.
I wish you was right my friend. I went to the Shell website and checked it out. Says API SN per Shell's website. Unless I looked wrong.Shell Helix Ultra is MB 229.5 BMW LL01 and also API SP made from GTL base.
