When you drove the other stinger did it have winter tires, what was the weather conditions? The other Stinger was on winter tires (and my dealer was upset about it because he told them not to so we can replicate the exact same situation). The weather was dry though.
When you picked it up what was the weather like(outside temp, snow, wet???) When I picked it up it was dry and probably around 6 degrees Celsius.
What is the temp and conditions at time of issue happening again? I have driven it in similar temperature since then while dry, and now also while wet but still in the 5-7 degree range. the problem is the most prevalent when I am making slow turns - like from a stop sign. Three point turns are laughably bad also.
What mode are you driving in? I am generally in comfort but I switched it to Sport also to see. I also tried turning off the traction control to see if it would change anything (I am not sure why but figured I would try stuff).
Are you still on the Michelin PS4's? Yep. I will definitely be on snow tires for next season, and early like November. But it was not worth it for this year anymore, plus I did not know if I would still have a Stinger since everything is up in the air with the car and how it will be resolved.
I'm no mechanic but I think your issue and it has been mentioned before is the fact your running summer performance tires in the winter.  As the temp drops, even on dry pavement these things will become "slippery than whale shit on an ice flow"  As you turn the rear is going to slide, your traction control/LSD (Limited Slip Differential) will kick in and remove power from the rear till they grip again.  I think what your feeling is how the system is suppose to work, especially since your using Michelin PS4s in the Winter. This does sound reasonable to me but the thing that doesn't make sense to me is why it is the worst when I am going slower. So on a day where it is 7 Celsius and dry, I should not have any issue (in my completely unprofessional opinion) making a slow turn even on the summers. But I might be completely wrong.
