Goldminer1
I have read that the Stinger GT2 has problems with the stock break pads and my car is having same problem. I'm going to upgrade brakes and want to know what kind of rotors and pads others have used and where successful with.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Rebuffing was the first thing I tried, worked temporarily but shudder came back. Believe the rotors are good just looking for aftermarket pads that are in stock.^^^Yes, rebedding the pads is the first thing to try. If you get smooth braking after that, you should replace with aftermarket pads then: no need to replace or resurface the rotors. If the braking is still rough/shuddery after attempting to bed the pads again, then either resurface the OEM rotors or get aftermarket.
@Goldminer1, welcome to the forum. As I just said responding to @Badal38257 you can rebed your OEM pads and rotors: if that works and you get smoothed out braking feel, then your OEM rotors are good to go, and get aftermarket pads on at once. You don't need to worry about the rear OEM pads/rotors, unless you are feeling shudder through your seat. Aftermarket rear pads are probably not necessary (it is relatively rare that replacement of rear OEM pads is because of braking issues: more so to enjoy having aftermarket pads all the way around, is all). As you have noticed, finding aftermarket rear pads is more difficult than aftermarket pads for the front.
If possible, find a good shop with a lathe to turn them for you then install the new pads, you'll be good to go.Thanks for all the info. I will replace the front pads. I will look at KDM first and see what is available.
I'll take a look at rockauto and the powerstop brand. The 2 numbers you gave, are they for front and back pads?I went with PowerStop Z26 - 6012 & 2144 for $80.79 & $74.79 (respectively) from Rockauto before shipping and discounts. I use those pads on all of my cars and never any squeaking or issues. Pretty simple installation as with all of these pads.
Yes, those are the numbers I used for the front and back. You can get those at a bunch of places, including Amazon. There's always 5% discounts on Rockauto, so make sure to find one of those codes.I'll take a look at rockauto and the powerstop brand. The 2 numbers you gave, are they for front and back pads?
Thanks for the info, I'm looking at the website right know.Yes, those are the numbers I used for the front and back. You can get those at a bunch of places, including Amazon. There's always 5% discounts on Rockauto, so make sure to find one of those codes.
Same here, Rockauto ftw.Yes, those are the numbers I used for the front and back. You can get those at a bunch of places, including Amazon. There's always 5% discounts on Rockauto, so make sure to find one of those codes.
