Is it possible to adjust EQ for each individual audio source?
StungBlueGT2
Sustaining Member
PB Florida, U.S.A.
I find the volume to be so much louder on XM radio than HD radio or USB like its boosted or something. If I set the EQ to sound great on Apple Play, USB or HD radio I can’t turn the volume up past 6-7 on XM...:confused:
Anyway to set audio settings based on the different input sources?
@StungBlueGT2 I also would be interested in getting feedback on this. Also, does anyone notice the fader sometimes adjusts itself when switching to different input modes? My Stinger will move the fader to the back, so I often have to manually reset to centralize sound.
I've seen it work this way on other cars I've owned - so it would be nice to see it work this way with the Stinger as well. Anyone want to test this out?
I’ve been trying but it seems to adjust EQ across all inputs no matter what source I’m in when I adjust. Does anyone know if this is even possible on our Stingers?
Or does anyone else agree that XM seems much louder than all other inputs? I usually don’t go past 15 with other sources, but even 5 is extra loud on XM?!?
My understanding is that you can control initial volume per audio source but not EQ. Having said that, I find that it doesn't seem to always follow my settings.
I have the same issue with XM being way louder than the other audio sources. Find 10 is loud enough with XM but crank the USB and FM up to the 20’s or 30’s.
I find that my XM is almost unlistenable after adjusting the EQ for my USB drive.. I'm forced to adjust the EQ each time I switch the input to XM.
That’s what I’m talking about. It sounds great if I tune for USB or HD radio but sounds horrible and overboosted when switching to XM, etc...:unsure:
Mine has done this several times as well
Is this just happening on the HK setup?
I believe this topic is discussed in another thread, but think this glitch is related to the Parking assist sound and Navigation auto fading/priority sound settings. I heard Kia might be making a software update to resolve it, but others have eliminated the problem by disabling those sound features.
Not 100% sure, but I think so since there are a lot of extra features in the HK system that arent available in the base version.
