Landboat G80
- Aug 29, 2021
Yesterday I went to the dyno to do some logs and get some results.
Intake, Exhaust, Fuel-It
432RWHP 499RWTQ on E30 MAP4
Can’t tell if this is substantially low or not, but seems like people these days are making 460AWHP with same mods.
Noticed that my peak boost barely touched 18.0 during the dyno and I’m used to seeing around 20.4, I did some digging into the logs and while the boost target for the JB4 was correct the ECU Boost is lower than it used to be.
The ECU hardly peaks at 12PSI now where it used to be around 14.4 PSI. (From looking at old logs) the weather is around 50F colder now, so I’m wondering if that has anything to do with it.
Was really hoping to be sitting at 450 considering RWD and mods, so I’m not sure if I’m underperforming or if this is normal? Either way it’s time for WMI.
Dyno in the log is at the tail end.
