Lane Powell
- Oct 10, 2021
Recently I tried running the E30 fuel mixture to get a little extra power with my JB4.  Began having issues with running lean and threw codes PO171 and PO174, I ran my tank down and filled back up to what should be mostly 93 now. Had my check engine light deleted and the car was running fine for a couple of days as it normally does.  Then randomly my CEL came back on with the same codes while driving the car normally.  I assumed there could be some leftover E85 in the tank and that after another refill on 93 I should be fine after deleting the CEL codes again. Then to my surprise, my Sport mode has stopped working. The car drives as it should in comfort mode, feels normal. I'm sure you all know the distinct difference between comfort and sport mode, but when I switch between the two there is no difference anymore.  It's not changing my gear ratios, hardening the suspension or steering wheel, or anything else that it normally does.  Do any of you know if this could be an electrical issue, or can the car not perform in sport mode with a CEL on? Im not to sure what is happening. Ever since I put E85 in the tank the car has been acting strange. Drives fine under normal conditions but acts like it doesn't want any of that pep it has in its step lol. Thanks!
